Rename created sample
Been using this app for a couple months, does anyone know how to rename a sample after I created it…
  1. Open the Sampler and hit “Edit”.
  2. Tap the “+” icon on the upper corner of the sample pad.
  3. Go to “My Samples” and tap the “i” button next to the sample name…
  4. Tap on the text field to rename the sample.
Sweet! Thanks, works as you described.
