Hi @Kaloyan, thanks for the details about your setup and the issue - this is very helpful! I was not able to reproduce this on my setup. Can you please try to capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
You’re welcome @Kaloyan. Engineering was able to access your crash reports and replicate the issue. I’ll report back here when I have more news. Thanks!
You’re welcome. I’m not sure. I have not been able to reproduce it myself and there have been no other user reports of issues so it seems to be an isolated edge case.
Hi again @Kaloyan. Can you please upload your djay Media Library database file to your Google Drive/Dropbox, enable sharing permissions, then share a link to it in a DM? Thanks!
I’ve sent you a link to a GDrive folder that has it.
But since that’s an Edge case only reproducible with an instance of a corrupted library, it’s not a big deal. I have backups, which I see as working fine and can use them.
Feel free to leave this issue aside. Both you & R&D have more important and valuable things to work on than an edge case of a corrupted library, if I may suggest.
