- Device model:reloop buddy
- Version of operating system: windows 11
- Version of djay: dj pro
- Hardware/controllers used: buddy
Your question: i came from record box to this software , in record box i could drag the track im reviewing to the desired place in a play list but on the dj pro i haven’t been able to find this option to rearrange the tracks am i missing something
pioneer xz
cdj3000
djm 750
2 x 1200
reloop buddy
making noise the neighbors can dance to
tony
cheers for the reply , as daft as this sounds im at a loss here , maybe this is something that can be added to the software, i usually play on the fly with me dragging tunes onto the deck from the 50 or 60 tracks in the list , in record box when doing this it then ads the track under the last track played and then builds the play list as your going , ATM i need to go back and find the tracks ive played from around 40 or 50 songs and then copy the info into a word document to post a play list for a set ( the joys of playing without a set format give you the ability to react to a crowd and still have a play list when finished )
i will look more into this cheers
Hi @Tony_Dean, you’re welcome. Maybe I don’t fully understand what you’re trying to do here. Can you please capture a video of how your workflow works in Rekordbox, upload the video to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Another video showing how you’re trying to accomplish the same thing in djay would be great too. I think this will really help communicate what you’re after. Thanks!
