AS SOON AS I HAVE DONE THE LAST UPDATE IN 30/04/16 , MY DJ PRO DOESN’T WORK WITH SPOTIFY !!
REQUEST FAILED: UNAUTHORIZED (401)
WHYYYYYYY???
WHYYYYYYY???
QUIT YELLING
could you please try to log out of Spotify and re-log?
if you want to log out or change your Spotify account, please do the following:
Hope this is helping.
I have the same issue, tried to uninstall both apps, logged out of Spotify and even went to my account overview on https://www.spotify.com/us/account/ov… and signed out on all devices. Still doesn’t work.
I can’t figure out how to log out of Spotify on Djay Pro, I don’t think it is possible.
Try again on the app does nothing.
I have sent support cases to both Spotify and Algoriddim. Hopefully, it can be figured out as soon as possible. This sucks.
The above worked perfectly, I just had to re-login to Spotify from Djay Pro. Awesome thank you for the support, cheers.
Thank you, that worked perfectly. Somehow I overlooked this setting. Cheers
