"Reset all" button for each Deck
As I’m using more and more stems mixing with EQ and filters and effects ,it could be really interesting just to have one button for each deck that I could press that would reset everything that I’ve done to change the track back to its normal settings, does that make sense? Would anybody else find that useful?
The reason I say this is because at times I’ve got so many knobs that I have to turn all on before of a bar for things to kick in on the drop and to just be able to press one button that could be mid mapped would be so much easier.
What are your thoughts, please?
Hi @Nubium, thanks for the suggestion. I will pass this onto the dev team for consideration. In the meantime, here are some potential options for you to consider:
  1. Navigate to the djay Settings>General>SONG LOADING and turn ON Rest EQ, FX, Tempo and Reset Neural Mix Controls.
  2. With a bit or work, you could custom MIDI map your own “Reset” button for each deck.
    a. To map multiple MIDI functions to a single button, simply long-press on the MIDI command and slide left to reveal **Duplicate.
    b. You will find the Reset MIDI commands near the bottom of the menu for each Deck.
OK great. Am I crazy or would it be useful?
I suspect you are not alone. Let’s see if other users upvote your suggestion…
Personally, I only use the Reset NM Controls on Song Loading as I prefer to have all of my main hardware knobs match with the UI.
