Hi, I have turned off reset EQ and the gain still resets to below nominal, is this something I can change please ?
I also wonder about the gain.
There is definately something strange going on with the levels. Adjusting for the right levels are so important for making a great mix
I use a reloop beatpad with djay2 and i can not use it for anything else than mixing modern tracks with more or less the same high level now.
I decided to leave the gain-buttons in the middle because as son as i touch them the level can “suddenly” change drastically up or down depending on how i turn it. it’s very frustrating and i do not know it this is a controller-error or it is just an bug in djay2. I have tried all the combinatiosn of settings i could think of
Good to know I’m not the only one, I’m using a wego3 and also not sure if a hardware or app setting, on loading a new track it sets a gain default to below middle, which is too love for recording and a pain to keep adjusting each time hopefully they’ll get back to me too with a solution,
Hi ARTCHEMICAL,
thank you for contacting us. Could you tell us which device you are using besides the Mixtour?
Thank you in advance.
Having the same problem with reloop Mixtour controller.
