Reset Neural Mix controls at new track load - Issue
@Slak_Jaw
Hi Slak_Jaw, today I noticed that the Reset Neural Mix controls doesn’t work Anymore.
In the Previous Version if you Load in New Track the neural mix Control / Crossfader FX, turned off. That is no longer the case and that is not good.
Hi @DJKamyR, please note the Crossfader FX are not considered Neural Mix controls so this is expected behavior. Yes, there are NM transition options within CFX, but we do not consider CFX as a Neural Mix control. If you want to disable CFX, you need to turn it off in the CFX menu.
@Slak_Jaw
I think that in previous versions this was turned off when a new trackload was added.
Can u pls. check this. Thx
Hi again @DJKamyR, I just tested this on 5.3.1, 5.3.0 and 5.2.10 and it behaves the same as on 5.3.2. I think you must be mistaken. Sorry I couldn’t be of more help.
I can confirm cross fader effects stayed on if selected in all versions from 5.0. I only know as I’ve been using them in every version.
Thanks for confirming @Dysfunk_DJ
Thanks guys, I guess I was in the wrong movie, but I was pretty sure I’d had this before.
Thanks for double check
You can midi map cross fader effects on or off though which I find really useful. I also have Tempo Blend mapped as well just in case I need to have a constant BPM for house, tech house mixing.
You’re welcome @DJKamyR
