Pretty self explanatory. I’d love the option to quickly reset all my neural eq to go back to active after selecting solo or muting the other channels one at a time.
I like to solo vocals and reintroduce them from time to time, and using midi pads it’s difficult to turn them all back on simultaneously, so I’d like a feature that operates essentially the same as the song loading option, but instead can be activated at any point with midi.
If there is an existing way of doing this I can’t seem to find it. I’ve attached a screenshot of the reset commands where I believe the option should live.
