I generally like the autogain feature on DJ Pro but sometimes I accidentally touch the gain nob and then it seems to switch to manual gain., at least for that track. How do I change this back to autogain?
Hi @Sparkomatic, this is intentional behavior in case you want to override the detected autogain level. The only way to reset the song back to the autogain level is to reload the song. A trick you can use is to load the currently playing song onto the other deck. By default, djay will create an instant double of the original song and you can easily cut from one deck to the other.
