Thanks for the gold skin, it is awesome, however, I am still unable to restore my red shin and FX purchases unto my iPhone.
Are there any plans to fix this, or a work around?
$9.99 is a lot to pay for something you can’t use.
Also, I bought the gold skin on my iPhone, how do I get to the skin store on my iPad to get it, I accidentally dismissed the pop-up about the gold skin?
I had to rebuy the gold skin on the iPad, and I found the skin store when I updated the app, now just need to know about FX purchases, they work on my iPad but not on my iPhone. (They used to, but I recently did a factory reset)
Please make sure “iCloud Drive” is enabled for djay 2 on ALL of your devices. Make sure you’re connected to the same Apple ID.
Now, please fully shut down djay 2, start it again and select “Restore” Purchases.
