Restructure playlist order.
Working on a routine and I realized there’s no way to sort by playlist order.
On top of that I can’t change playlist order either. It defaulted to BPM
You can. If you sorted it by bpm it wont change. You need to press reset when selecting a sort option. Then just drag files and arrange them. Make sure its not sorted in any form first as it has to be on reset. Check pic
Hi @Reggie_Flores,
Thanks for posting to the community!
As @PRO24DJS pointed out, these two actions are possible in djay and I have marked their post as the solution for your question.
Additionally, I have moved your post over to the Questions category for better community management. Have a nice day!
