Found this Husky Build-Out case. With a few mortifications it’s almost perfect to make an all in one with battery pack for your rev 1. The case cost $30.
Thanks for sharing @Five-0
That’s pretty cool. The Rev 1 is a great controller.
. After watching your YouTube channel on the Rev1 case you modified I decided to try it with this case…. (I should have started the post off mentioning your YouTube. Channel) . you have a great channel…….thank you for the inspiration
Is there a link to the item?
https://www.homedepot.com/p/Husky-Build-Out-22-in-Modular-Tool-Storage-Tool-Case-22842/322630772 Looks like the price is going up
What is the name of the YouTube channel?
Thanks it looks like I was already subscribed to your channel. I did not see a video regarding the case you installed for the Rev 1. Wanted so see what it looks like before I invest.
What modifications were needed?
Had to cut the case. The side walls are hollow so i heated up steak knife and trimmed until the Rev 1 fit. Took no more than 15 mins. I ordered some 90 degree rca cables and 90 degree usb extension ( not needed). The case top comes easy.. I should make a better video. Because the set up is amazing!
Part 1
Part 2. Sorry for the bad recording
