I’m using Pioneer REV7 with latest firmware. I’m using Djay Pro AI on iphone so iOS.
When i trigger the FX, it triggers both the REV7 internal Fx and the Djay pro software FX. Is there a way to decouple them? or maybe set the software FX to 0 depth or something?
Hi @Mrbigmouthbeats, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”.
- Are you using the built-in REV7 MIDI mapping or a custom edit?
- Please share a screenshot of your djay Settings>Audio Devices when your REV7 is connected to your iPhone.
- Are you sure that the djay software FX are being added on top of the REV7 hardware FX or are they just showing a visual representation of what is happening on the hardware? Maybe you can capture and share a short video of the behavior for review? Thanks!
