- Device model iPhone 12pro max
- Version of operating system iOS 16
- Version of djay 5.1.2
- Hardware/controllers used rev7
After I instant double a track. I can’t change the tempo on the new track. Have to move the pitch rapidly to get it working.
Hi @Scott_Taniguchi, thanks for the details about your setup.
No. The tempo doesn’t change, the hardware fader is temporary locked.
I do match the state of the fader before I instant double.
But after I instant double, I immediately want to be able to adjust speed with having to “unlock” the fader regardless if it’s in the same or slightly different position in the software.
This should be a very obvious work flow issue.
Okay, thanks for the addition info @Scott_Taniguchi. Can you please try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Hello! It’s been more than 7 days since my last reply. I’m going to consider this topic completed for now so I can focus on others. However, please feel free to respond and we can definitely revisit this. Thanks!
