Reverse/Brake.not working in windows version
Reverse/Brake.
The reverse part works, but not the brake partt. Tried changing the stop time, and it makes no difference.
Works in mac version, and is independent of stop time.
Hi Steve,
thank you for your post. Could you try to explain the issue you are facing in an exemplary video?
That would help us a lot.
Thank you in advance.
We do I expect a response?
Video as requested at link below.
https://drive.google.com/file/d/1Kk5n…
Using shortcut CTRL+1 Brake not working.
This function does work in Mac.
