REVERSE PLAYBACK on Reloop controllers and Djay AI
Hello Algo Team. Would it be possible to add reverse playback of a deck with a simple key combination (like SHIFT + PLAY ) ? A function that could be control by MIXTOUR or BUDDY from Reloop. So far, playing in reverse is possible through FX, but it is quite not straightforward to use. Reverse playback with an easy access would be a must for many people I think. Thanks.
There’s a censor / reverse button on my DDJ SX2 which does just that.
I haven’t got it rigged up right now but the fact I’ve got a button that does just that function would suggest it is midi mappable through the editor interface.
:+1:t3:
thank you for the info.
Can we find the midi mapping editor on algoriddim site ?
