I suggest that we can right click a track and add it to a playlist. It’s way too hard right now to make playlists.
Would love to see a feature, where we can set a target playlist and then map a button or pad too add songs to the target playlist.
Thanks for the suggestion @Johan_Rosenberg. I will forward it to the dev team for consideration. In the meantime, please use the blue Vote button at the top left so we can gauge user demand for this.
Also good right click showing the playlists or crates that file already exist
It would be great if you can select several songs by ctrl-clicking and then when you right click you get a list of all your playlists to add them to. ![]()
@Johan_Rosenberg can you please confirm that this request is for the Windows version of djay?
Add to playlist: Right-click option.
I have lots of music. Before a performance, I create a playlist of the tracks I need.
It would be easier if I could do this through a menu.
Click the right mouse button to open the menu. It will have a list of ready playlists and the option to create a new playlist.
- The most recent playlist is at the top.
- All created playlists are here.
- All playlists are listed.
- Add tracks to a new playlist.
This is option from DJUCED 6.
Hi @Zirrex, please use search before creating new topics. I’ve merged yours with this existing one. You can cast your vote for this feature at the top left of the page. Thanks!
