Roland DJ 202 on iOS
YOUR QUESTION:
  1. looking for suggestions/links to cables to use to hook up Roland dj 202 to iPhone (usb-c)
Thank you
Hi @Shankedmics,
  1. Looking at the product images, the Roland 202 doesn’t look like it has a separate power supply socket so it is likely bus powered over the USB-B connector.
  2. In this case, you will need to connect a powered USB-C hub to your iPhone so you can power the controller and charge the iPhone.
  3. I personally use the UGREEN Revodok 1071 USB C Hub: Amazon.com
  4. Then you’ll need a USB-B to C cable from the controller to the USB hub. I personally use the Chroma Cables from DJ TechTools: Chroma Cables USB-C to B – DJ Controller USB-C Cable | 1m & 2m – DJ TechTools
I hope that helps!
Thanks for the reccs!!
You’re welcome. I recommend you also do some research to confirm if the Roland 202 is USB and audio class compliant. This is required for compatibility with iOS devices.
