I know they don’t have class complaint audio and aren’t supported, but I’m wondering if the midi is class compliant and can be mapped to algoriddim. Specifically the jogwheels. If that’s possible, I was going to get one and try to use kt with the audio interface I use for DVS. Does anyone have one they could test for class compliant midi and if it can be mapped?
Hey @Themainman3 ,
Thank you for asking this question here in the Community.
Unfortunately, if the controller is not class-compliant (and, therefore, needs drivers which you cannot install on iOS), I doubt you will be able to use it with djay, even if you find a way to custom-map it.
But it would be great to also hear the other Community users’ take on this topic. Cheers!
