I’m using RoughRider3 compressor in my djay pro AI iPad app to spice up my sound a bit. It’s a great plugin and especially helpful when you mix party tracks from the 70s and 80s with new hits.
Thing is, the dark title-header of the master out plugin page is overlapping the preset selection. So I can’t select a preset from RoughRider3. I have to manually adjust the values according to my needs. That would be no problem, if the settings would be saved. But they aren’t. I have to re-enter the values every time I use the app.
Would be nice, if the plugin window could show the whole plugin below the title header.
