Greetings.
I am looking to route the audio from each deck to separate tracks in Ableton Live using Jack Audio (https://jackaudio.org/).
I haven’t been able to figure out how to get JACK to recognize DJay - any suggestions?
I’m on windows 10 btw…
Greetings.
it might be better to tell us what your end goal is and we might be better able to suggest a workflow that, y’know, works…
I’m looking to internally route audio from each deck in DJay to individual tracks in Ableton Live.
I have Traktor and Ableton set up that way by using JACK
so in ableton you’re doing what to the streams, proceesing them with plugins/addons?
I’m making mixes/remixes, and I want each deck to record to a separate track in Ableton
yeah, I’m sure it won’t work because they’re a few steps ahead of you.
just record one song at a time using the built-in recorder and import to Ableton.
