Run iPad and Mac with Automix at the same time
Hello @Slak_Jaw, How do I get it to work if I have the iPad connected to the FLX10 on socket “A” and am operating channels 1 and 2 and if I have the MacBook connected to B on the Pioneer device and want to operate channels 3 and 4, so that the auto-mix on the MacBook also runs on channels 3-4? If I set it in the settings so that the output should be via 3-4, it sets the headphones to 1-2 and then I can’t hear any sound through the speakers.
Thank you
Hi @DJKamyR, this is currently not supported on the FLX10.
  1. Changing the audio output to 3-4 does not relate to Automix. Outputs 1-2 and 3-4 are the audio output channels of the controllers audio interface and do not have anything to do with mixer channels 1/2/3/4 or decks 1/2/3/4 on the hardware.
  2. djay’s Automix always runs between decks 1 and 2 and this can not be changed.
  3. Decks cannot be reassigned on the FLX10, so you can only use decks 1 and 2 (and therefore Automix) from one connected device at a time.
Aha, ok, thanks for the clarification, Slak_Jaw.
No problem. You’re welcome @DJKamyR
