When I record a sample in djay ai, it is not that loud as the original in the deck.?!
What can I do to have the same loudness?
thank you
Jesse
thank you
Jesse
I also suggest for this. I would like to amplify my samples after I record them on the decks.
Hey @jessefunk , @DJ_Norm
Thank you for posting regarding this!
The option to adjust individual samples’ volumes is not yet available on djay, but it’s something we’re working on
We’ll keep you posted with any updates as soon as available. Cheers!
Apart from samples being quieter, I also note that session recordings are at a much lower amplitude as well.
Any recoding that is then loaded back into Djay shows the waveform as really ‘flat’ and it sounds quieter.
I have to load it into Audacity to amplify the recording to make it ‘normal’ again.
So, not directly linked to recorded samples but I think any recording through Djay is quieter than the original source.
