Hi @NiceThings, Thanks for the details about the issue and your setup - this is very helpful. Can you please also share a short screen recording of this?
Hi @NiceThings, thanks for the video - that definitely clarifies things. I tested this on my iPad and couldn’t replicate it so I need to pass this onto our engineering team to see if they can. I’ll report back when I have news.
Hi again @NiceThings, our engineering team was not able to replicate this either. Can you please check if the issue also happens when you trigger the samples on screen instead of via MIDI? Thanks!
My apologies, I can’t believe I missed a vital part of the repro!
1. launch App
2. sampler > record options (lower-left)
3. change duration from default (4 Beats) to 8 Beats
4. turn on metronome
5. press REC
6. **RECORD EVENTS USING GUI or MIDI**
7. observe REC ‘clock’ and metronome click and PLAYBACK pattern
You won’t see it via the metronome, you’ll hear it from the event notes:
Only the first 1bar is recorded and repeated, the 8 beat extension does not respond.
Thanks for checking in @NiceThings. Unfortunately, our team still has not been able to replicate this on their setups.
I suggest that you backup your djay Media Library database and any custom MIDI mappings, then uninstall djay, reboot your device, and reinstall the latest version of djay. You can find the files above in the following locations:
iOS: using the Files App, navigate to Locations->On My iPhone/iPad->djay->User Data
