Device model MacBook Pro 2019
Version of operating system latest version
Version of djay latest version
Hardware/controllers used ddj 800
hi, im using the ddj 800 and ive been trying to switch between sampler banks using the button on the controller but as much as I try I can’t get it to work. is there a fix for it
I need to double check with the engineering team because I don’t have access to a DDJ-800. However, I’m pretty sure that the Sampler Bank buttons are not supported in djay, because the Sampler in djay only has 16 Pads total. 8 on the left deck and 8 on the right deck and there are no MIDI commands in djay for loading or switching different Sample Packs. You need to change these manually.
Hi @Temi_Siyanbola, I confirmed my statement above with the engineering team. The Sampler Bank buttons do not have a corresponding feature in djay. Thanks!
