Sampler: Can I use Start/Stop as a toggle?
can I switch the Sampler response to toggle start/ stop? Right now it is set to start (play) till end.
Thank you
@SirHannes unfortunately, Toggle is not currently available for the Sampler. However, you can MIDI map Shift + the Play Sample button to Stop Sample.
Okay, that’s a workaround I can use. Thank you for your help! :slight_smile:
@SirHannes no problem. You’re welcome
