Go to “My Presets” in the Djay2 sampler.
Select “Save New Preset”.
Back to sampler and select “Edit”
Choose a button to change and click on the note icon.
Choose any sample
Click “Done”
Test the sample and it should work.
Now choose any other Preset and then go back to the one you just modified and you will find that your changes were not saved.
WORKAROUND:
There are two ways to save your presets until this is fixed.
1: When you have finished arranging the new preset as you want it and have pressed “DONE”. Go back to the “My Presets” menu and click on “Save New Preset”. This will make a copy of your new preset, and it WILL save it.
All that’s left to do now is delete the one you first created and rename the new copy.
2: After you make your changes and select “done”. Unload Djay2 from memory.
That means pressing the home key once, to get back to the main screen. Then double click the home key to bring up the task list and take Djay out of memory.
This forces Djay to save the preset.
For Algoriddim Support:
Create a user preset ie “Preset 4”. Click done. Go back into “My presets” and delete all Pre-sets. “Preset 4” is still showing. Remove Djay from memory. Re-start Djay and open Sampler. it will show “Preset 4” with all samples still working (even though you just deleted all presets), but go into “My Presets” and the list is empty!!!
I installed a fresh copy of DJay2 with nothing added, and the same results.
