While I am using samplers, I discovered a delay. I could not sync with the beats in the music. And I launched VirtualDJ to compare the latency. With the controller, I pressed one of the pads. VirtualDJ’s sample was played first. Then, djay PRO played its sample with the delay. There is a significant latency. Is there any configuration for that? I couldn’t find anything in the settings.
Thanks.
Hi @Ramazan_Vapurcu,
So that I can better assist you could you please answer the following questions:
- What version of macOS are you running?
- What version of djay are you using?
- Are you using an external controller to trigger these samples? If so, is it Bluetooth enabled?
- How long is this delay? Milliseconds, a few full seconds? etc.
