Samples Migration from Djay v.4.2.3 to Djay Pro?
does, please, anyone know how to migrate the samples that have been created in Djay v.4.2.3 to Djay Pro?
Thank you in advance
Hi Spini,
This should happen automatically. If not, simply copy the files from:
~/Music/djay/Samples
to:
~/Library/Containers/com.algoriddim.djay-pro-mac/Data/Library/Application Support/Algoriddim/Samples
Hi Warren,
thanks for your prompt reply!
Done and problem was solved.
