Hi, since the last update to 4.1.4 I lost the samples I had created and the sampler is not working anymore !
I can’t load or create new samples !!
It’s still working on iPad
Not having the issue with iPad, All my samples are still there and working fine
Hi to all… Just wanted to share the solution I found.
I used CleanMyMac to reset the app instead of uninstall and reinstall like I did many times before and it worked fine.
Now I have access to all the features again.
