yeah there’s a volume control right in the middle of the sampler.
Not from what I can tell. Just picked up the pro last night.
How do you add your own samples to IDJ Pro? Never done that before, so would like a suggestion as to what program to use to create samples/rip samples and then how to import them into Djay for the IDJ Pro.
Thanks. I will try this. Can you or anyone recommend a good app for creating samples? Either to sample fromnan existing track or to create my own. Could be on the Mac or iPad.
Hi There,
I’m a fairly new iDJ Pro user. I have been playing with the sampler section of the software and would like to know if you are able to label each of the samples you create apposed to being stuck with the default names of Sample1, Sample2 etc.?
Also, will there be an option to add more buttons possible on a by page controlled swip left or right?
Finally can you please add a ‘Kill All’ Button to the sampler?
TwistedWave…however know that mp3 files create a tiny amout of silence (in any program) at the front so it’s better to store samples as lower quality (smaller) wav files
How to add my sample to Android PAID version? Not very usful if this doesn’t work.
