Save All Effects and recall
Hi there. I think it would be a great idea to be able to save the effects chains and recall them. For example, when playing R&B and hip hop, basic reverb, delay are good but then switch to house and gates and more fancy effects are better. Whist playing it is too slow to load a new set of effects presets.
I’m sure many would appreciate this feature and to be able to toggle through a set of presets using midi mapped buttons or shortcut keys.
Thanks for your consideration.
DJ Midas.
Thanks for the suggestion! I’ll share this with the dev team for consideration.
100% and also the possibility to save the parameters with it.
Thanks for the additional input @GrzlyAdams
