Is there any way to set custom midi mappings to be saved in iCloud so that they are automatically available on all (Apple) devices in use without having to copy them manually? That would make switching devices easier.
Hey @Chris_R ,
Thanks for sharing this here in the Community
Hope to see more users liking or commenting as it’s a good suggestion.
In the meantime, I’ll check with the Dev Team if we can open (or have already) an internal request. I’ll keep you posted with any updates on this.
Cheers!
Hey @Chris_R ,
Hope all is going well!
Writing to let you know that an internal request regarding your feedback and the option to save customized MIDI mappings to iCloud has been created.
I will happily keep you posted with any updates on the topic.
Hope you will find this information useful. Cheers
