Saved cue loop colouration
Mac iOS latest MacBook Pro 22
Dj Pro latest 5.2.6
PX5
2 x k2’s
Hi.
Not sure if this is any good or not ?!
It would be to me !
Would there be an option to have the saved loop markers that underline the waveforms in the same colours as saved cue points 1-8 or in loop case
1-6
Red, Blue,Orange etc
The way I set up and play is to use cue point marker arrows as loop reminders.
And the small opaque underlines are not that visible in the 4 deck layout I use. A coloured representation would be far more useful.
Then I have an option do away with the coloured cue point arrows on top of the waveform, Or use in conjunction.
It would also help to see the underline colour length of loop coming up. 1,2,4,8,16,32.
As the loops then could be a represented in colour order. Like the cue points
I understand that just pressing the saved cue loop button puts you at the start of that saved loop.
I use k2s and there’s not that many buttons for 6 saved loops on each channel. !!
But I don’t play like that.
I like to have an element of some live input. Some times I don’t use the saved loops set at all. In moment sort of thing.
Just an option for consideration.
It’s a mental visual thing for me. Not for everyone.
But nice to have that option.
Hi @Daveworzel, this isn’t currently possible, but I’ve changed this topic from a Question to a Suggestion. I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
Much appreciated that you’ve read and reached out. Thanks.
You’re welcome @Daveworzel. Happy to help!
