Hi, I have saved loops on Djay Pro on android and i want to access this loops with djay control mix ultra:
I cannot find a way to launch my saved loops from the pads of this controller… is there a way to do this?
Hi @yogiman67, welcome to the Community! Please note that the Saved Loops performance pad mode is not supported on this hardware. You will need to use the onscreen controls within djay for this. I hope that helps!
Thankyou, ok i understand… i will than launch the saved loops from the tablet…
Anyway i wander if there is an other hardware that can perform that action as it is very important for what i do with the app…
You’re welcome @yogiman67. I’m not sure which Android supported hardware has saved loop functionality. However, if you use djay on iOS, macOS or Windows you can customize the MIDI Mapping to replace one of the existing performance pad modes with saved loops.
Ah ok that is a good option actually! Thanks!!!
You’re welcome @yogiman67. I’ll link some FAQs below for how to MIDI map in djay:
