as the title suggests, when master tempo or key lock is activated the sound of the scratches is distorted.
this happens above all when the scratch is slowed down (braking), the sound is not reactive and is not very clean. if I disable the master tempo then the scrath is linear and clean. i could encounter this exact same problem with rekordbox. while for serat and traktor the problem does not exist . does anyone know how to fix?
I am writing you with an update from our QA Team who kindly ask if you are able to share a screenshot of the calibration readout from within djay, as well as a clip showing the operation of your turntable configuration so we may further reproduce this issue for testing on our end.
Thank you in advance and we look forward to getting to this sorted out!
maybe it can help further. I uploaded another video where you can see the same problem with a different setup. this time I used a record and cartridge by connecting the turntable to the PHONO input of the mixer. the connection is correct and everything works perfectly but when I activate the master tempo I find the same problem of the scratch when braking. I infer that the problem does not come from PHASE .
