How can I set up DJay and/or Mixtrack platinum fx to scratch mode. Now using jog wheel it just rewinds whole track fast back or forward?
I had that too, but it is able to be fixed in the midi menu, and worked fine after that
Thanks I’ll try that. Did you check those settings somewhere or just with intuition?
As @djjoejoe already mentioned. This issue was being fixed with djay version 3.7.1. make sure to update
Updated and working! So nice - thanks for advice, I was so depressed before that update
but now more than happy !!
