Hey guys I want to thank you for the great product. However I have one (very important) issue that keeps arising. At random times, the headphone output for cueing is scratchy. The sound is quite similar to the “Crush” FX effect. The only way to make it go away is simply to wait, or choose a new song, which can prove to be very frusterating. This has occurred on both of my two different DJ setups, so it could either be a bug with your program, or my computer simply does not have the horsepower to output two outputs. However when checking activity monitor I only get ~20% CPU usage from your program. What could the issue be? Thanks.
My two setups:
DDJ-SX used as a Midi Controller with CUE coming from the headphone out and a Resonessence Labs Herus USB DAC as the main audio out
Renonessence Labs Herus USB DAC as the main audio out and the built in output of a MacBook Air as the cue
Machine Specs:
Macbook Air Mid-2011
4GB 1333 MHz DDR3 RAM
1.8 GHz Core i7
Mac OSX Mavericks 10.9.3
