Even with charger connected after a few mins the screen fades and I have to type in my password pin no to get back to my track. Is there a way to keep the screen lit and keep the programme running continuously?
Thanks for helping out!
Auto lock is not switched on!
Sorry thought you were referring to rotation lock. Auto lock was 2 mins. Will give it a try, thanks
have you tried taking auto-lock off?
Settings>General>Auto-Lock>select ‘Never’
yes, altering from 2 mins to ‘Never’ will cure the problem
