Search Field - keyboard loses focus and accidentally initiates hot keys
I have an update on this issue! I seemed to have found a way to make it happen…
When you search something in apple music it is fine, but if you click “show all songs” or go into any other “folder” (album/artist/playlist etc.) in the results of the search and then try and search again (click back into the search box and type a few letters) - thats when the search box becomes deactivated! The attached video shows me doing this just now - hopefully this helps?
Thanks for the additional info and video @mp3juggle. This is very helpful!
Hey! Yes that is the issue! But on my setup I don’t need to go to “show all songs” it just does the same error in the first step and on tidal. Thanks for the video @mp3juggle
I have the same problem since the last update of Djaypro.
It runs on a MacBookPro M1 2021 (16Gb RAM, still on Monterrey), i use two controllers an old Numark MixTrackPro3 and a Quneo for triggering loops, neural mix, extra cue points etc. I always disable the keyboard shortcuts cause very often I ran Ableton Live and Volta on the same machine (i still dont believe that this little laptop stands firm with no bugs running stream stem separation/video generation/extra instruments and recording in real time!). But i’ve noticed that (even when i’m just running djay pro with a good connection) the search field for tidal looses the focus, it’s very anoying but i can live with that … this started to happen with the last two updates.
Salve
Yes it’s anoying. Sometimes I have to click back into the field for every single letter. Since I disabled shortcuts it feels pretty safe again but still, for every letter in an artist name?
Hi everybody. I have ended here looking for answers since I have experienced the same issue than @Timo_Fielker .
It happens since last Djay Pro update and this weekend I have suffered it several times during two gigs. Typing on the Tidal"s browser suddenly the song that is being played restart (!!) as well as I aren"t able to type more letters and the result is this for some strange reason (a shortcut? Does the cursor change its position to the worst place it could go?) I usually can skip this issue typing very slow, letter by letter, and checking it doesn’t happen, but it can’t be a definitive solution. Following your advices I’m going to proceed to deactivate the shortcuts. If you have any news about this issue don’t hesitate to share it with us, I will appreciate it, thanks!
Hi @Timo_Fielker, @mp3juggle, @Penumbra, and anyone else following this thread,
I just saw the update to version 5.2.8 for my iMac via the App Store and installed it.
One of the fixes listed in the update notes is:
  • Fixed: Cursor sometimes jumps out of the search field unexpectedly.
I haven’t had a chance to test it yet, but let’s hope this also addresses the issue discussed in this thread.
Please share your findings!
Hi! Oh that’s super nice! I can’t find any update yet, I’m in germany. Maybe my app store takes a bit longer. But that’s good news! Thank you all!
Yes.
I am in Netherlands and have it since this morning, but already read about it since yesterday.
Hi everyone,
Thank you for your continued updates and the additional information shared.
It has been extremely helpful to our teams in the testing process.
We are still looking into this issue and should have some updates very soon for you all.
We appreciate your patience and positivity. Please keep this thread updated with any and all new information.
Thank you.
Hey everyone! Had gig last night. After the latest update everything works just fine! Thank you so much for the update and the fix!
You’re welcome @Timo_Fielker. Thanks for confirming.
