I’m using DJPro with a Pioneer Wego3 on a MacBook Pro (2015)
Since I upgraded my OS to Sierra I am having issues with the search bar function in both Spotify and iTunes libraries. After I type the first letter I go to type the second letter and it automatically bounces off the search and will by default use my keyboard keys as a hot key. This is a bit of an issue as it can start the track again/jump to an inappropriate hot-point/marker! This has screwed up some of my performances so now I am on tender hooks/ terrified and need to be overly careful every time I have to use search bar function. It Doesn’t happen every time just about 60% of the time! (once is too often!)
Anyway, love the product and I hope you guys sort this with your next update.
