Search inside USB when using USB HID Mode (OneLibrary)
YOUR SUGGESTION:
I’m loving using a USB stick with OneLibrary on it on my XDJ-1000MK2s, but I notice there’s no Search capability when you are browsing. You can only browse the stick you are attached to as a source.
On the native Pioneer device, when you navigate to the top of the tree you will then have the option to search and enter search terms on an on-screen Qwerty keyboard.
This would be really handy and save needing to use the computer screen, as you feel like you are still navigating your own USB stick (if that makes sense?) It’s about user immersion for someone using their USB stick via OneLibrary and plugging directly into the hardware.
Thank you for your consideration.
James
Thanks for the suggestion @James_Gillies. I’ll share this with the devs for consideration.
