IMO the issue is not with DJay Pro but with how you’re searching.
If you just type three letters, of course you will get many results, containing every word that has those three letters. I just tried the same in VirtualDJ and got over 800 results. Low, slow, blow, flow, glow etc.
However if I search for rida low I get the result right at the top.
Yes, but what happens when you search for the same in iTunes?
Then you get ‘Low, low’ as a first result and not last, without sorting on any particular column.
(So there is something different in Djay.)
Because you search exactly for the repeating words ‘Low, low, low’ (with spaces and commas) or even for only 'Low ’ (ending with a space), you should expect that this track result would show first because it significantly differs from results where the word ‘low’ is only a part (e.g., ‘FolLOW Me’, ‘big bLOW’).
So, it looks like Djay is e.g. insensitive to repeating words in the search string.
While others tools like iTunes, Google, and many other applications manage to make the search algorithm smarter.
My advice (which applies to any searching, not just DJay) is to search using distinctive words, not generic ones.
For example if I want to to find you on Google, typing in big will give me many results, but not what I want. The top result is a Tom Hanks film, followed by Notorious B.I.G.
When I search for dj big blender though, all the results list what I’m looking for.
Correct!
Infact: if i was to google him more correctly, I’d type DJ_Big_Blender Almar Hijlkema, Part & Mix Dj from Netherlands Google will be so happy and zero down my search to almost him.
Same concept applies to djay: use your ID3 tag info as much as possible if you want accurate results.
@DJ_Big_Blender if you want to know the worse search engine, try the apple music app! Returns zero results even if you type at least 1 word you know for sure exists in the song title!
Of course, I understand that using more specific search terms (especially title and artist) helps achieve better search results. That’s common sense.
However, my point is about efficiency during DJing. During a performance, you often don’t have the luxury of entering detailed search queries or sometimes can’t even remember the artist’s name. In all cases, you need to act quickly and rely on the robustness of the software’s that gives the best search result IMO.
The issue I experience with Djay Pro is that the search algorithm, in specific cases, does not always present the most relevant results first, even when the search query is clear and specific. (In my case, searching for “low, low, low” is quite specific, and even that doesn’t work.) This is in contrast to other platforms like iTunes, where the same search query does yield the correct results (so it is possible here also).
Therefore, I believe that Djay Pro could improve its search algorithm to better respond to specific queries with repeated words and context.
Addition to “Search Issue (not always giving the best result first)”
Hi again!
I’ve re-investigated this issue because in live situations I still regularly encounter poor search results, which can be quite disruptive when you need to quickly find a track.
While re-investigating, I recorded this video and came to the stunning conclusion that the local search bar (Search in My Collection or Search in Playlist) does NOT only search in the Title and Artist fields, but also in other fields like Grouping, Album, Composer, Genre, and possibly more.
This clearly results in a lot of unnecessary results, leading to confusion and noise for the searcher. This issue is further compounded because all fields seem to carry equal weight. As a result, a track might appear at the top of the search results simply because the keyword is found in, for example, the album name or composer field. In my example, all tracks from the album Pump Up The Base appeared, even though I was specifically searching for Pum Pum (Remix) in the track name.
In my opinion, it is highly unusual for DJ software to search so broadly. Users don’t expect this as a default search behavior, and in most cases, it only adds unnecessary clutter. I’d argue that in at least 95 out of 100 cases, a DJ or user is simply searching for a Title or Artist. So why are results from all these other fields being included by default?
And why is Djay ignoring duplicate words when I explicitly search for them (such as ‘Low, Low’ and ‘Pum, Pum’)?
I hope this can be addressed in the very near future. It would significantly improve the user experience and make searching in live situations much more reliable and efficient. Thank you for considering this feedback!
In my opinion it is NOT unusual. DJs don’t just search for artists or titles.
For instance, right now in VirtualDJ I have search enabled for 17 different tags. That’s the maximum, but as a minimum I’d use seven, because I search for comments, genre, year, key, BPM as well as artist & title.
Also (IMO) when searching, it’s up to the user to search for words specific to that thing, rather than generic words, to narrow down the results. i.e. for “Big Time Sensuality”, don’t search for “big” or “time” - search for “sensuality”.
