I downloaded and buy DjAy Pro 3 days ago and try all functions. So fine so good. I have 7000 mp3 Songs on pc what is not really much. If i use the Search function, it only search the current folder. i have no option to search on all folders, what is really important. next is, if i have a folder with 3000 mp3 the search is useless. it use to much time and ressources. Why?
Hi @djme2k, welcome to the Community! Sorry to hear you’re experiencing this issue. Can you please confirm how you have imported your library into djay and what Source you are searching in?
It would also be helpful if you could please try to capture a short video of the issue and upload it here. Please note the maximum file size is 200MB, so if your video is larger than that, you’ll need to upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the file here. Thanks!
