- Device model: iPad Air 3rd Gen
- Version of operating system: iPadOS 26.3.1
- Version of djay: 5.6.3
- Hardware/controllers: no hardware connected
- there’s no search bar for playlists on iOS/ iPadOS like there is on macOS
if I’m searching for a playlist, I’m searching through all spotify
all I get is a small window and no way to search or organize the playlist
C) EXPECTED RESULTS:
is there a way for iPadOS to add this search Bar for playlists on iPad and iPhone?
thanks
Hi @max_mtl, this is currently not supported on iOS. However, I have changed this to a suggestion topic and have forwarded to our dev team for consideration. In the meantime, please use the blue Vote button at the top left so we can gauge user demand for this feature. Thanks!
Hi again @max_mtl, is there a reason you would like this search in-line and separate from the general search which shows songs in full Spotify catalog + matching playlists in your library?
Yes. Because when you find the playlist you can only scroll through it.
If you then want to search by key or bpm you can’t.
On macOS there is a specific search bar for playlists.
It really helps when you have a lot of playlists.
I could maybe work around it if we could had Spotify songs to my collection
The first picture is from searching using the search bar (Spotify catalog + matching playlists)
The second is scrolling through my playlists and finding it. It has the option to sort the songs the first one doesn’t
This is on iOS (iPhone 15, iOS 26.3.1, djay 5.6.3)
On iPadOS it’s even worse because it just open a small separate window instead of opening the playlist
You can see the difference in my original post
See on iPad when you actually click on the playlist you searched
Thanks for the additional context @max_mtl - this is very helpful! We’re already looking into ways to improve these workflows.
thanks, I like how responsive you guys are. keep up the good work
You’re welcome! Thanks for the positive feedback @max_mtl
