Searching "My Files" on macOS shows no results
  • Laptop**: Macbook Pro i7 2.6ghz intel core, 32gb ram
  • Version of operating system *(macOS Ventura)
  • Version of djay *(5.2.9)
  • Hardware/controllers used *(DDJ-SX2) it happens offline too
Summary of the issue:
In “My Files” I go to the search window, I toggle to “Search My Files” I start typing in, song title or artist, and I get the spinning wheel for a long time with no results.
If I change it to “Search Folder” then it works as long as I’ve highlighted the folder I want to search in.
This only happens in the “My Files” Section.
This works fine in the “Playlists” section
I have tried this on older versions and it has the same issue, this only happened after I upgraded to DJay 5.2.9
Hi @eecy_cee, sorry to hear you’re experiencing this issue. Thanks for the details about your setup and the issue - this is very helpful! I haven’t been able to replicate this myself so I need to pass this onto engineering. To help communicate the issue clearly, can you please try to capture a short video of it, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Hi again @eecy_cee, I just spoke with engineering and they think you may have an issue with your system Spotlight index.
Please run the command:
mdutil -s /Volumes/Macintosh\ HD
and change the volume if it’s not the default Mac volume then see what the status is.
More info can be found here https://discussions.apple.com/thread/252598143?sortBy=rank
Hi Slak_Jaw thank you for responding,
You are correct, it is my spotlight thats causing this, to make things faster and stable for me on an oldish intel Mac, I decided to dualboot, my Mac with Ventura/Sequoia, I decided to disable “Spotlight” cause I read how Spotlight causes intel macs to overheat and use up a lot of memory ram,
my laptop is running cooler and uses less memory ram, I didnt realise DJay uses Spotlight, This makes sense now,
As always thank you Slak_Jaw for your help, I truly appreciate it :pray:t3:.
Excellent! Glad that solved it. You’re welcome @eecy_cee. Thanks for the positive feedback - it’s always appreciated :smiley:
  • Device model *Mac book air *:
  • Version of operating system *macOS sequoia 15.5
  • Version of djay (e.g. 5.3.2):
  • Hardware/controllers used (flx10):
Hi @Massimiliano_Mancini, please use search before creating new topics. I have merged your new topic with this existing one. Please try the solution above and let me know if that helps. Thanks!
hi Slak_Jaw, thanks for all, I solved the problem like this Rebuild the Spotlight index on your Mac - Apple Support
You’re welcome @Massimiliano_Mancini. Glad you were able to sort it out. Thanks for the follow up.
