Searching Songs using Cyrillic characters
search
Is it possible to fix the search for songs with Latin letters of Cyrillic names?
Hi @xenohack,
Welcome to our Community, and thanks for asking about this. So that our team can more easily investigate this, could you please tell me the following:
  1. What device are you currently using?
  2. Which OS version is running on your device?
  3. Which djay version are you using? (If you are using an iOS/ Android device, please open the djay settings and scroll down to determine the version number.)
  4. Could you please share a couple of example song files you use with Cyrillic characters in the name when you encounter this problem? You can share the files easily by dropping them here.
Thanks in advance!
