Hi all,
I’ve figured out that the layot is no really usable for a DJ with a controller.
You are not able to see ALL functions (FX) or loops which are set at the first view.
So you have to switch anytime to see what would be active. This is not enough for a professional software like this. If a controller is connected I should be able to see what loop would be activated and also which FX I would activate on the buttons. But currently you have to swich between FX part and also loop part.
The same behavior with samples. So please implement a layout to see all features on one screen.
This is normally common for DJ Software e.g. Traktor or Serato.
Tom
