it is possible to use my usb output? as 2nd sound card? the only option that I’ve found is the one that split channels
Note: This conversation was created from a reply on: Now that djay pro Windows is released….
Hey there,
which djay version are you using and which device are you working with.
Next time please create a new topic or search for topics which are about the same issue.
Forked, reason: off topic.
Cheers,Lukas E.
