Separate mix / headphone cue on Meta Quest?
  • Device model: Meta Quest
  • Version of operating system: Quest OS v76
  • Version of djay: 1.1.0
  • Hardware/controllers used: None
Your question:
Is there a way to separate the main mix output and the the headphone cue output (when holding the hand next to the ear) so I can hear the cue on the headset speakers only and somehow have a separate output for the mix without the cue?
I heard that this is possible with external DJ controllers, but is there also way when using the Quest only?
Hi @algorridler, welcome to the Community! Unfortunately, this is currently not possible.
